Old 06-18-2007, 02:25 AM
intermax is on a distinguished road
Fanuc Om-417 X Axis Servo Alarm
Hi Friends,
I have JOHNFORD nc milling with FANUC OM controller.I have problem with it.It gives an error during machine start up.The monitor showed error:
- 417 x axis servo alarm.dgtl para
- 427 y axis servo alarm.dgtl para
- 437 z axis servo alarm.dgtl para
Can somebody help to stepdown this problem.Thank you
Old 06-18-2007, 03:08 AM
L. Sakthivel is on a distinguished road
Your Servo motor Parameters are deleted. I think you are reloaded the parameters. Pl. check the following parameters and enter
X axis Y asix Zaxis
8100 8200 8300
8101 8201 8301
8102 8202 8302
8120 8220 8320 Motor type
8121 8221 8321 Load Inertia
8122 8222 8322 Direction
8123 8223 8323 pulse / rev
8124 8224 8324 pulse / rev
Pl. check the above parameters
Old 06-18-2007, 03:19 AM
Dear Friend,
Thank you for the information.I am new boy to cnc.How do i enter the parameter cause of the machine give an error during start up operations.
Old 06-18-2007, 03:20 AM
what keys i have to press to enter the parameter menu?
Old 06-18-2007, 05:04 AM
select MDI Mode
press para/ DGN Key
Select Parameter Page
Press Page down key
Select setting 2 page
move cursor to PWE - 0
enter PWE - 1
go to parameter 8100
and enter the apropriate values
if any problem to enter the value press Emergency and try
Old 11-21-2007, 04:08 AM
david en is on a distinguished road
hi iam having with 95 model Chen ho mcv1000 with a fanuc om controller and i was told by fanuc that i need to get system parameters from 1 to 9000 in the pwe settings so if any one has these settings it would be much appreciated
servo alarm 417-427 437
Old 11-21-2007, 06:00 PM
LOOKING FOR CHEN HO 95 MODEL WITH A FANUC OM
I HAVE SERVO ALARM 417-427-437 AND I NEED PWE PARAMETERS 1TO 9000 AS THIS IS WHAT FANUC AUSTRALIA TOLD ME ANY GOT ANY IDEAS
THANKU DAVID
Old 07-01-2009, 06:16 PM
hectorbach is on a distinguished road
HI David en, can you fixed the problem you had with 417 and 427 alarms..? please let me know what did you do, please..? it looks like I have the same problem.
Old 04-27-2012, 12:59 PM
komikap is on a distinguished road
Unhappy fanuc O-MD
hi
i have a machin CHEN HO fanuc O-MD
year 2000/01/24
model mcv-900
s/n 2000222
parametre lost and diagnostic lost
i dont have a parametre and diagnostic liste
i want to your help please
401 servo alarm fanuc 6t ncprecision Machine Problems, Solutions , Wireless DNC, serial port 9 04-25-2009 05:25 AM
Fanuc 6m 416 X Servo Alarm Yabbos Fanuc 7 08-20-2007 04:30 AM
Fanuc 6M servo alarm versa1 Fanuc 4 12-20-2006 01:21 PM
Fanuc 18I Z axis servo Alarm 410 Ninus Fanuc 3 09-21-2006 11:16 PM
Fanuc Servo Alarm herbmarkovit Fanuc 20 11-20-2005 10:53 AM
