Old 06-14-2007, 01:48 PM
AZDEN is on a distinguished road
Help With a Different Application for a Fanuc 21T
Hi All,
I'm using a Fanuc 21T on a custom wire bending machine. The current configuration is using the C axis to feed the wire and the X axis to manipulate the bending mandrel.
The program uses a G90 to set the initial position Of the X axis then switches to G91 to position the mandrel and feed the wire incrementally off of a large spool (production quantities range from 60 - 3000 pieces).
The C axis position reads out in degrees ( 0-360 ) And the amount of wire fed is usually less than 360 degrees worth. Being in incremental mode, the start stop position is irrelevant as the counter can run past 360 and just start from where it stops.
I have an application and want to run in absolute all the time. Is there a way to reset the C axis counter to zero after each cycle? If not, any suggestions on alternative solutions will be appreciated.
Thanks.
Old 06-14-2007, 02:14 PM
Sump Cleaner's Avatar
Sump Cleaner is on a distinguished road
Azden,
You just need to look up the parameter number for for the C axis in the coordinate system you are using. Write a line in your code that says;
#(whatever the number is)=0. and your C axis will be set to zero in your coordinate system.
Jon K
For the 18T it looks like the parameter number is #5223
Old 06-14-2007, 03:33 PM
Sump Cleaner,
Thanks I'll look into that. I just came across a polar interpolation program that may work also. Know any tips or tricks?
Thanks again.
Best VMC for my application? FTSCNC General Metal Working Machines 7 06-23-2008 09:04 PM
Servo Application dyingbreed Servo Motors and Drives 4 05-26-2006 01:55 AM
What a great application! wholepair Machine Created Art 2 03-23-2006 05:29 AM
Need Application Advice slevy Linear and Rotary Motion 1 03-20-2006 05:20 PM
Help with a Stepper application? Enzo Stepper Motors and Drives 2 08-22-2005 06:30 AM
