Results 1 to 7 of 7
Thread: Fanuc Alarm 440
    Mar 2006
    Fanuc Alarm 440
    Can someone explain what this alarm is? I have a Fanuc Wire EDM machine with a Fanuc 18I-W control. The alarm 440 message says "A regenerative discharge circuit alarm condition has occurred".
    I am down and of course it is Saturday when the service dept. is closed.
    Jim
    Dec 2003
    The way I read this is that either a axis regen voltage was exceeded, fast deceleration etc, which means it is re-settable.
    However If the alarm is on constantly then the discharge unit has either an overheat or a permanent failure. I would think.
    Does it show an axis concerning the fault?
    Mar 2006
    It shows the X axis. When I look at the alarm page it list all the axis's.
    XYUVand Z.
    I looked at the power supply module and it has a #8 in the alarm window which says it is an excessive regeneration alarm.
    If it is the X axis the is triggering the alarm could it be something as simple as a ball screw needing grease causing friction. It only does it when burning. The approach feed won't trigger it and moving the machine in manual mode doesn't either. I haven't tried a 2 axis cut to see if it makes any difference. Right now i am cutting a 4 axis shape that I have done before.
    Thanks for the response
    Mar 2006
    I forgot to mention, you can't clear the alarm with the reset button but if you shut the machine off and restart it you comes back normal. You can burn for a few minutes before the alarm triggers. It does not take the same amount of time either. The first time it did it was after only a minute and once after 10 minutes.
    Dec 2003
    Normally the Regen unit comes into play when doing High accel/decel moves repeatedly.
    Which could be happening but over a very small movement.
    The high decel produces a high regen voltage that has to be dissipated, if it is not (regen unit failure) you probabally get this alarm.
    Normally binding causes over heat or over current alarm.
    Do you have Alpha drives?
    Mar 2006
    Alpha Drives?? The machine is Fanuc 1IA machine with an 18I-W control.
    The power supply and amplifier modules model numbers start with an A.
    The machine is traveling at only .050 per minute. I just did a 2 axis cut with no problems. It was a straight cut with only one axis moving.
    Right now I'm back cutting the four axis part just fine but expect it to alarm out at any time.
    JIm
    Jun 2008
    Pakistan
    PSM unit of FANUC shows A at seven segment
    Hi
    I m suleman khosa and have one problem in our FANUC module of CNC lathe Takisawa TC-200(Japan).
    It have one power supply module A06B-6110-H015. Maker of part is FANUC. When i ON the machine then its shows alarm of radiator fan failaure at screen and at power supply module seven segment display shows "A" at screen. I checked in manual its say that connector or any thing loose but there is not any type of that reason is diagnosed. please help me in that matter.
    My personal email id is subhani_engr1@yahoo.com.
    1. Fanuc alarm
      By Fullvision in forum General Metal Working Machines
      Last Post: 11-27-2012, 02:02 PM
    2. fanuc 6m 421 alarm
      By actionman in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-01-2010, 02:19 AM
    3. Fanuc 446 Alarm
      By blakester in forum Fanuc
      Last Post: 03-30-2007, 03:57 PM
    4. FANUC 0M - alarm 520
      By promech in forum Fanuc
      Last Post: 02-19-2007, 11:41 AM
    5. Fanuc 16M #445 alarm!!
      By fastolds in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 07-14-2006, 08:27 AM
