Results 1 to 5 of 5
Thread: OM loss all parameters. How to reload?
    Jun 2007
    I'm new to this forum. We have Enshu mill with Fanuc OM series. One of the guys pressed reset and delete buttons together during power up and wiped all parameters. We had saved the parameters before. How can I reload them?
    Apr 2007
    India
    Loading Method by manualy
    Switch ON the control, keep it in Emergency stop condition. Select the parameter page and enter the parameters manually one by one.
    Load the Optional Parameters 900 series
    Load the Axis parameters 8100, 8200,8300 series if it is Digital Drive
    Switch OFF and Switch ON again
    Select the Diagnosis Page
    Load the Parameters of Timers, counters value in 300 & 400 series
    Check any PC setting values supplied by machine tool builder Enter that values.
    If you are having any Macro program in 9000 series that also to be entered if that is deleted.
    Jun 2007
    Thanks for the reply. I manually loaded all the parameters. I'm getting alarm 580. I don't have 8th axis. How can I get rid of it. It still has not ready message.
    Don Diegoo
    Aug 2006
    Iran
    H! check it again , may be you have input wrong bit by manual input ! always happen ! check it again
    Apr 2007
    India
    Check the Parameters Once again as told by Mr F. Sharifi.
    1. reload parameters in fanuc 0m
      By samu in forum Fanuc
      Last Post: 11-29-2009, 11:04 AM
    2. tacho loss -LED 11
      By Daninwyoming in forum Bridgeport and Hardinge Mills
      Last Post: 04-22-2007, 12:11 AM
    3. Reload executive software
      By inertialabs in forum Bridgeport and Hardinge Mills
      Last Post: 03-10-2007, 12:20 AM
    4. Cancelled due to loss of enthusiasm.
      By widgitmaster in forum DIY CNC Router Table Machines
      Last Post: 11-08-2006, 08:50 AM
    5. How to reload a ballnut?
      By bgolash in forum DIY CNC Router Table Machines
      Last Post: 04-07-2005, 11:49 AM
