I can transfer from the PC to the Controller, but not from the controller to the PC. I am using a non-handshaking custom cable made to the specs found many places on the web for Fanuc. Is there a parameter that I've overlooked? Anybody have any ideas? Thanks... |
| SR 830 DR OFF(2) The data set ready signal for reader/punch interface 2 went off. <custom cable made to the specs found many places on the web for Fanuc> doesn't tell us anything specific. Post the pinouts for the cable you made. |
| This is fun. Your link shows four cables, and since you stated you're NOT using handshaking, I'm GUESSING you're using the 9pin to 25pin Null Modem cable and NOT the 25pin to 25pin cable. Am I right? To save time, my next question is going to be, "What software are you using?" |
| Check parameter 0038 What is in it? Also, SETTING values: PUNCH CODE = ISO, INPUT DEVICE = 1, OUTPUT DEVICE = 1 Are your "SETTING" values correct? The alarm states a problem in interface 2 and I think you should be using interface 1 Let us know. |
| This list matches your list with a few others listed http://www.aggsoft.com/cnc-dnc/fanuc-11t.htm Again, make sure INPUT DEVICE=1 and OUTPUT DEVICE=1 on Setting Screen 1 under parameters |
#10
| I'm using DNC4U for file transfer. The TV check is zero, Punch code is zero (ISO), Input device is 1, Output device is 1. I changed these last night. Is a power-down/power-up required for these parameters to take effect? |
| mori seiki mv junior "jog rset" error | Arsonist | General Metal Working Machines | 10 | 03-24-2010 06:45 PM |
| "Runtime error 9 - subscript out of range" on Techno CNC interface | zhoudfoster | General CNC (Mill and Lathe) Control Software (NC) | 4 | 10-25-2009 10:57 PM |
| BOSS8 "+Z OVERFLOW" error message | jonny | Bridgeport and Hardinge Mills | 11 | 05-29-2008 04:12 AM |
| V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" | rfdoyle | Bridgeport and Hardinge Mills | 4 | 10-08-2007 03:35 PM |
| 11T "SR824" communication error | grweldon | Fanuc | 7 | 02-15-2007 05:41 PM |
