1"-11.5 NPT I.D.Thread Programming
Results 1 to 3 of 3
Thread: 1"-11.5 NPT I.D.Thread Programming
    Sep 2005
    Default 1"-11.5 NPT I.D.Thread Programming
    Having a hard time trying to program a Fanuc OT lathe to produce this thread. I'm not sure of the data inputs for G76 cycle. Can someone post a block of code to help me out?
    Thanks!
    Gold Member dcoupar's Avatar
    Mar 2003
    Try the example on the attached .pdf
    Attached Thumbnails Attached Thumbnails 1"-11.5 NPT I.D.Thread Programming-1-1-00-11-5-npt-thread
    May 2007
    I can give you the correct G76 information for a 1"-11.5 pipe thread Tuesday. I can give you the correct format and explanation now.
    G76P000155Q30R(optional & is a decimal)
    G76X1.25Z-1.P565Q120R.0344F.087
    P in 1st G76 block works in pairs. 1st pair is the number of spring passes, 2nd pair is the pull out (which is .1*F-value in this example), 3rd pair is the compound infeed (55/2=27.5). Q-value is the min. DOC (.003), R.001 would be a finish pass of .001 DOC.
    2nd G76 block P= thread height (per side), Q=DOC of 1st pass (per side), R=X-offset amount (per side) to thread correct taper. Start position of Z.5 & end position of Z-1. would =1.5*tan1.78333= R.0467
    I have found that the R-value sometimes has to be fudged in order to maintain the correct go/nogo gage depths because of tool pressure.
    EDIT: This is for newer controls. Older ones use a 1-block call in the format
    G76XZDKFA with D-value not containing a decimal point. If I remember correctly it uses an I-value for a tapered thread.
    So G76XZDKIFA Not sure where the I-value has to go, or if it makes a difference.
    Here are a couple samples that are used on our machines.
    X1.09Z.3M8
    G76P000155Q30
    G76X1.2365Z-1.15R.0451P700Q120F.08696
    OR DEPENDING ON CONTROL
    X1.09Z.3M8
    G76X1.2365Z-1.15I.0451K.07D120F.08696A50.
