fanuc OT
Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: fanuc OT
    Mar 2005
    UK
    Default fanuc OT
    Hi all,
    I have just bought a Nakamura tome tmc 20 lathe.
    Has anyone got an NC printout they can send me. I need to creat a post for our cam system. I can get the thing to rough and finish but screw cutting seems a problem. The tool just overides in X every time and I can't understand why.
    Cheers,
    Paul.
    Dec 2006
    What treading cycle are you using. I know g76 has a parameter that sets cut depth. mine was set at .0001 so the first time I threaded with it it took about 20 minutes. I believe if you use p1 it uses your d amount for depth of cut, I don't remember for sure so I use g92 instead. My controller is 11te so it doesn't use the double line cycles.
    Joe
    Registered Sump Cleaner's Avatar
    Dec 2005
    Paul,
    Here is a snippit from our TMC 15 with an explanation
    M1(THREAD 1 3/16-20)
    G20G40G80G97G99
    T0404(SER 0750 K16)
    (INSERT - 16ER-20 UN)
    G0X1.2S2500M3
    Z.15M8
    G76P000060Q150R10
    G76X-1.114Z-.37R0P320Q140F.05
    G0Z1.M9
    G28W0M5
    M30
    G76 P(m)(r)(a) Q(min) R(fin)
    G76 X(Øfin) Z(len) R(i) P(k) Q(1st) F(L)
    WHERE
    m = SPRING CUTS (01)
    r = CHAMFER AMOUNT(00)
    a = TOOL ANGLE (80 60 55 30 29 0)
    min = MINIMUM DEPTH OF CUT
    fin = FINISHING ALLOWANCE
    Øfin = ROOT DIAMETER
    len = LENGTH OF THREAD
    i = THREAD RADIUS DIFFERENCE
    k = THREAD HEIGHT (RADIUS)
    1st = 1ST CUT DEPTH
    L = THREAD LEAD
    Hope this helps...
    JK
    Mar 2005
    UK
    Hi JK,
    Thanks for taking the time to send that to me. I can work with this.
    Thanks again,
    Paul.
    May 2006
    Sweden
    Does oT use the 2 line G76 cycle?
    Mar 2005
    UK
    yes it does...
  7. #7
    May 2006
    Sweden
    Wich fanuc uses the one liner cycle?
  8. #8
    Dec 2006
    I know 11 uses 1 line.
  9. #9
    Gold Member dcoupar's Avatar
    Mar 2003
    I believe the 0, 16, 18, & 21t controls may be able to use the 1-line Multiple Repetitive Cycles (G71-G76). Check your settings for "TAPE-F". If 0, it uses 2-line cycles, if 1 it uses 1-line cycles. Check your operator's manual under "Memory Option Using Series 10/11 Tape Format". Be aware that this also changes sub-program call loop format to M90 Pnnnn Lnnnn.
  10. #10
    Mar 2005
    UK
    Default error alarm
    I can now run my program through all the operations without any errors. However when I cycle the program again, it alarms out when it reads the first moves within the roughing cycle. The error is listed as 'feedrate not commanded or feedrate inadequate'. If I restart the machine it runs ok for the first time then errors out if I try to cycle it again.
    I take this to mean the program is setting up something later in the program which, when read again, creates a fault but I can't think what it could be.
    Any ideas?
  11. #11
    Mar 2003
    It would help if we could see your code, but...
    1. Make sure there's a feedrate commanded in or before your first feed move.
    2. Make sure that G99 (IPR) is active. If you're using G98 to pull stock, etc. you'll get that alarm if you have a small F value.
  12. #12
    Mar 2005
    UK
    Default More trouble
    Hi, and thankyou decoupar for the G99 advice. It worked. Great.
    Does anyone know a drill cycle that retracts in Z to an absolute figure, say 3mm. At the moment it retracts by an incremental amount.
fanuc OT
fanuc OT
