Old 05-01-2007, 08:50 AM
TURNER is on a distinguished road
Macro B On 10t?
Hi, does any of you smart fellas know if macro is an option on a fanuc 10T, and or which parameter settings can do activate it.
Many thanks
Turner
Old 05-01-2007, 01:59 PM
Al_The_Man's Avatar
Try 9111 bit #0
Old 05-02-2007, 06:17 AM
Originally Posted by Al_The_Man View Post
Try 9111 bit #0
Thanks Al, i tried to change 9111 display came back with 'LOCKED PARAMETER' , note we did this with the write enable parameter on.
Any ideas??
Thanks Turner
Old 05-02-2007, 07:39 AM
Al_The_Man's Avatar
IIRC the 9000 parameters on the 10 have to be loaded in hex?
Also I believe the Locked Parameters is normal.
Old 05-03-2007, 02:31 AM
Hi Al, thanks for your help, i have a question, we currently dont have the m/c parameters backed up. If i sent them to pc via rs232 do i have to set para8000 to all ones + e-stop before punching as you do when reading?.
What i was thinking was to back the parameters up, edit the required parameter then send them back in.
Thanks again...Turner.
M6 macro ben_heinman General CNC (Mill and Lathe) Control Software (NC) 2 03-30-2007 12:37 PM
Macro help fpworks Fadal 3 02-07-2007 04:13 PM
Macro B jorgehrr G-Code Programing 2 01-31-2007 02:23 PM
what is a macro? ljoe1969 Autodesk Software (Autocad, Inventor etc) 3 07-12-2006 08:12 AM
One More Macro ? 16I Bluesman General CNC (Mill and Lathe) Control Software (NC) 4 02-07-2006 05:06 PM
