Results 1 to 8 of 8
Thread: Cylindrical interpolation
    Mar 2006
    Thumbs up Cylindrical interpolation
    I've turned on the option for cylindrical interpolation for a five axis Citizen with Fanuc 18 control. Supposedly this machine is capable of this cycle. It's not working yet. Anyone know any tips or tricks for getting the G107 option going?
    Dec 2006
    what cam system are you using, mastercam X etc? you need to go to mis values when you are setting up the tool parameter and set it to either -1 or 1. G107 has be in a line by itself and just before the tool is going to engage the work. I was having struggles with this and recieved some great help in the Mastercam forum. I also had to edit my post so that everything was do in the proper order. This was a trial and error at the machine and when I got the correct i modified my post to give me the correct output. You can also try the machine maker and ask for a sample program that they would use at say Westec and see what it is. Hope this helps. my 2 cents
    Mar 2006
    We are using Partmaker, (no forum for it yet as far as I can see) but it must be similar. We will go to the machine maker and ask for a sample program (a template I like to call it). Great suggestion! As it turns out, Eastec is a month away. Maybe those exhibitors will be feeling helpful....
    Dec 2006
    the 2 cam systems are probably similiar so just have a cruise thru yours'. i learned a lot of new swear words trying get the polar and cylindrical interpolation to work. best of luck at Eastec. enjoy the day, mine has just started
    Registered dcoupar's Avatar
    Mar 2003
    Here's an example from a Daewoo. Should be similar to yours.
    N100 (ENGRAVING LETTERS J & R )
    G0G80G40G18
    M35
    G7.1H0
    G28H0
    T1111
    G97M33S4000
    G0Z-.7
    G0X3.1.C15.806 M8
    G1G98
    G18W0H0
    G7.1H1.45(H IS RADIUS)
    X2.9F5.
    C3.951
    Z-.45
    G3Z-.45C15.805R.15
    G1X3.5F200.
    Z-.3C-3.951
    G1X2.9F5.
    Z-.7
    C-10.8664
    G3Z-.45C-10.866R.125
    G1C-3.9514
    C-10.866
    G1Z-.3C-15.8057
    G1X3.1F200.
    G7.1H0
    G30U0M35
    G30W0
    M1
    Aug 2008
    INDIA
    anyone can say the macro variable no for current tool in spindle?
    Mar 2003
    What machine? What control? What does this have to do with cylindrical interpolation?
    Registered luky's Avatar
    Oct 2008
    China
    if Fanuc,#148?
    1. Attaching cylindrical open bearings?
      By boblon in forum Linear and Rotary Motion
      Last Post: 02-26-2007, 11:07 AM
    2. Cylindrical interpolation Question????
      By theemudracer in forum G-Code Programing
      Last Post: 12-09-2006, 02:31 PM
    3. Cylindrical workpiece
      By MAX711 in forum SprutCAM
      Last Post: 12-03-2006, 09:11 PM
    4. cylindrical fixture
      By MBG in forum General Metalwork Discussion
      Last Post: 06-24-2005, 10:50 AM
    5. interpolation
      By rimcanyon in forum General Electronics Discussion
      Last Post: 04-08-2004, 02:10 AM
