401 servo alarm (VRDY off)
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: 401 servo alarm (VRDY off)
    Member sting007's Avatar
    Feb 2015
    Default 401 servo alarm (VRDY off)
    hi,
    I've Puma 6s with fanuc 0, after applying the lost parameters, i found the mentioned alarm,
    could any one help me to solve that.
    sting
    Mar 2007
    Check your circuit breakers first in your electrical cabinet if the are all alright then check your optical cable that connects the servo drives. Here is a screen dump of your error and the actions to take.
    Attached Thumbnails Attached Thumbnails 401 servo alarm (VRDY off)-untitled-jpg
    Apr 2007
    India
    SERV0 ALARM 401
    Which Fanuc Model & Axis Drive you are using. If it is Old analog & Digital Drive, Pl. check the 100V ac to the Drive. It is always through the Emergency Relay
    Nov 2007
    HI,
    I have a mill with a Fanuc 0M controller. The drive hardware is siemens...
    I have the 401 servo alarm (VRDY off) that is thread is about...
    It all started one day after the machine was off for about 2-3 months. I had to turn it off, and back on about 8 times to get pass this 401 Error.
    What is it does is upon power on, I hear one relay.. the screen shows some software numbers, and then jumps to the XYZ 00000 screen like it always had before, but now, it sits there about 5 seconds like it wants to work, but I hear another relay trip and up comes the 401 servo alarm.
    I have looked at the parameters, but I really do not know what they are suppose to be. I purchased the machine 5 times ownership old, and no books or parameter papers came with the machine. Also, it seems that the siemens controller is not popular with people.
    I have changed the motors around, and it does not help. They are all 3 the same according to the tags on them. I have pulled the controller board, and this appears ok..
    There are some LED lights that come on.
    First on bootup, a green LED pops on, and then back off. When the machine CRT displays the XYZ 00000 screen, all LEDs are out, and then that relay trips and a red one on the SIMODRIVE 6RB21 board lights up ( V5 ) at what appears to be the Y axis set of lights. Then the green one, and a red one comes on at V4 and V1
    So, somehow I think it is the limit switches, but they are all free and I hear relays clicking. I can put some wedges in the switches like the machine is home, and the error does not come on, but neither does the machine. the boot up hangs at the software version screen and will not continue to XYZ 00000 screen. Pull the wedges, and it will continue to boot, but then 5 seconds or less, the 401 Servo Alarm....
    Any ideas?
    thanks
    Nov 2006
    Scotland
    For the Siemens drive.
    Check the dc link voltage at the axis drive.If it is ok,check the drive healthy signal which is 24vdc and goes in terminal 73.2 and comes out 72 or vice versa on the axis drive.If you do not have the healthy signal the problem is in the drive.These older drives do not like dampness.If they have been standing a while disused in a less than dry atmosphere it is better to give them a blow with a heater for a few minutes before powering up.
    Nov 2007
    I would need a little more definition of what these items are called for a mill tech vs a master mech and computer engineer..
    I call the drive axis motor.. just plain electric motors.
    I call the SimoDrive a computer controller.
    I call the Fanuc a user interface controller.
    Now, checking the axis drive sounds to me like checking the computer controller at some test point.
    The drive healthy signal at 73.2 sounds like some test point on that big cabinet where there are many wires running around.
    What is a axis drive... what does not like dampness. Because I sure have alot of humidity in my shop. No heat or AC, so temp inversion is really bad some days.
    Its hard for me to understand that it will boot up and sit there about 5 seconds sometimes and it wants to work, but then that relay will trip and the 401 error comes up. I can disconnect the encoder plug and get X error communication, and then take off Y and get the same error.
    thanks for your help, I need to make some parts...
  7. #7
    Nov 2006
    Scotland
    Fastfieros.
    The Fanuc part is called the cnc control.
    The Simodrive is an axis drive and/or a spindle drive.
    The axis drive motors are servo motors.
    I`m afraid I cannot give any more help as the voltages within these components are lethal if you come into contact with them.
    I suggest you contact a cnc repair guy.
    Mark.
  8. #8
    Nov 2007
    I have had this machine for 3 years. I have worked around higher voltages than the 240 running around inside this cabniet. I wear and adhere to proper safty equipment and guidelines. I have a EE degree.
    I worked with the machine some more today. I called Fanuc and they suggest the problem is in the Siemens controller area. One time today, it booted to the ready state for about 10 seconds... in the past when it did this exact same thing, all I had to do was turn it on and off about 10 times and it finally stayed in the ready state.
    I think it is the 24v signal as this is what the Fanuc customer support indicated also. is it 24v DC or AC? I can remove the caps from the drive motors. I have already removed these 20 plus times. Even if it is missing 24v signal, what am I going to replace to fix this issue? I looked up all the boards in the controller.. I have the following with the XYZ conections... 6RB2100-0NA21, Control Board
    From what I remember it all started when I overran the table on the x axis, and worked fine the rest of the day, but when I tried to turn it on the next time, it did not boot up to ready. it was the error....
  9. #9
    Nov 2006
    Scotland
    There is a lot more than 230 volts running around this cabinet.The dc busbars will either be 210 or 320 volts.These are open and run along the botton of the axis control.
    The old dc drives do not like dampness,stray voltages short on the cards and cause failure,sometimes with a very loud bang.This problem is not confined to Siemens only.
    Yes the problem is in the Siemens unit.The Fanuc control is not getting a drive ready/healthy signal.It is 24vdc.It comes from where I told you.Have you checked the dc fuses feeding the stack cards?
    It is possible to remove axis cards and make the drive think there is only one or two axis but you need to know what you are doing.
    If you have elec schematics for the machine you will be able to follow this signal if you are an EE.
    If the fault is not obvious to me I have spare cards and can replace each card until I find the faulty one.I also isolate the Simodrive from the cnc and set each axis up using a battery box.It is relatively easy to do as Siemens always uses the same terminal numbers from drive to drive.
    What make is the mill?
  10. #10
    Nov 2007
    No schematics to the machine : ( I am about number 5 owner... I purchased the machine without parameters even loaded. I was lucky enough to fine a phone number on a piece of paper in the machine that was for AIT in CA.. Sidney was the person who built the machine in 1989... it is a WebbMatic 800 with this lovely Fanuc Om-A and the Siemens controll.
    Sidney sold me the parameter sheet, and I loaded the machine and got it working. It never has zero home correctly since I have had the machine, but my work is not that precision, just needs to look pretty.. The machine is very tight, so I would like it to work a little more. The spindle head is nice, and not noisy..
    BTW... here is some of my work http://www.fastfieros.com/projects
    I am a hybrid engine installation specialists.. but I did computer networking and systems testing in the past also.
  11. #11
    Nov 2006
    Scotland
    You can download a manual for the 6RB2100 drive at the Siemens Automation and Drives website.It is a nightmare site to navigate but can be done.
    Mark.
  12. #12
    Nov 2007
    here is a pic of the inside... I marked the LED's that are on with the red arrows.
    here are the fuses... all of these are confirmed good.
  13. #13
    Nov 2007
    Hey gridley51
    Can you help me a little more here.... please....
    I downloaded the manual on the 6100... I studied 73.2 and somewhat understand how it works...
    I read the voltages at G0 card on these pins....
    Ok, 9 and 63 are at the top... and they are jumped together with a green wire.
    9 = 17.3 V
    63 = 17.3 V
    64 = 33 V
    73.2 = 16 mV
    72 = 20 V
    I read that 73.2 should be the same as 72 if all was working right. I cannot tell what is bad however. The relay K22 is clicking it sounds like.
    I even jumped 72 and 73.2 together to see what happens, and it clears the 401 error, but I get a 404 error with that jumper, and it reads VDRY = ON with that. So, I removed my jumper, and back to 401...
    thanks......
  14. #14
    Nov 2006
    Scotland
    9,63 and 72 are a bit low for 24vdc.I will need to check the allowable specs but you have over 20% voltage drop there.
    I would expect 0v on 73.2 if the drive has a fault.
    I can`t remember what 63 is,I suspect it should be 24vdc also.Will have to check tomorrow.
    What is the dc link voltage at?
  15. #15
    Nov 2007
    Well, after reading and reading these block diagrams, I can not figure out where DC link is in my cabinet..
    the paper reads....
    L to master switch
    Something that is X501 ( I cannot find a X501 anywhere )
    Then to K1 ( relay, I cannot determine what is or where )
    Then to N
    K1 on the other page is at the big relay with L1 L2 L3... and then PE
    Now, L1 is 120v AC , L2 is 120v AC , L3 is 220v AC
    then this goes to K2...
    Then it shows that K2 has something to do with Board G0 at X121... now I know where this is, and pins 9 and 63...
    So, it looks like K2 relay closes, and provides power to U V W ... it appears that this is 165v AC at U V W ....
    What is the point of DC Link you want me to find?
  16. #16
    Nov 2006
    Scotland
    Are you reading L1,L2,L3 coming out the transformer?If you read L1-L2,L1-L3 and L2-L3 you should have near enough even readings.The 165vac gets rectified to 210vdc and this is linked across the amplifier cards in the axis drive.This 210vdc is what is known as the link voltage.The amplifier cards are also known as stack cards.It is going to be difficult for you to fault find without substituting boards.Give your boards to a Siemens repairer to check for you.Most of them have racks set up and can put your boards in one at a time to test.While the boards are getting tested check the brushes in each servo motor and while the brushes are out give the carbon a blow out with dry air from an airline.If any brushes are worn well down or chipped and broken inspect the commutator as well.It is ok to pull these motors apart but do not leave the rotor out the stator for long or you will lose magnetism.I usually check the motors on there own on a 12v truck battery.They should run nice and smooth in both directions which you can do by reversing the leads.If they run smoothly at 12 volts I have never had one fail at higher volts although sometimes I will connect them to a battery pack on an electric forklift where I can select up to 72 volts.
    Mark.
  17. #17
    Nov 2007
    Ok, I have found what you want me to measure..
    it is identified as
    X1 = 156v AC
    X2 = 203v AC
    X3 = 175v AC
    at the rectificer output to the capacitor is 307v DC
    not a very stable 165v and the output of the rectifer is high compared to 210v DC you mention, but I cannot find on these block diagrams many voltages I am suppose to see..
    Attached a pic of that transformer.. the yellow ones on the left are the ones going to the rectifier..
    Attached Thumbnails Attached Thumbnails 401 servo alarm (VRDY off)-transformer-jpg
  18. #18
    Nov 2007
    I have a little more info today..
    I found a blown fuse on number one...
    Number 1,2,3 go to an Allen Bradley relay 100-A09NA3 Ser B
    then from there is 8,9,10 to the drive transformer..
    this AB relay is buzzing today. I changed the number one fuse and tested the one I put in there for continuity, and sure enough, upon power up, it must have blown that good fuse, because it now does not have continuity.
    Is this relay bad since it is buzzing?
    Is the transformer bad causing the buzzing, and blowing the fuse?
  19. #19
    Nov 2006
    Scotland
    Is the fuse before or after the transformer?
    The buzzing is either caused by dust/muck on the pole faces of the contactor or the coil voltage is low or lastly the coil is faulty.It`s most likely to be on of the first two.
  20. #20
    Nov 2007
    the fuse block is right after the master switch.
    1,2,3 go to the fuse number 1, 2, 3... then the output is 8, 9, 10 to the AB relay.. then the output is to the drive transformer. This is making the drive transformer not getting the correct input voltage so the out put voltage is correct. ( i think )... well, at least the output to the SimoDrive, and the SimoDrive is showing the error.
    Either that transformer is bad or that relay is bad it seems like to me. I have heard that AB relay in the past do some strange noise things.
    I cannot find a part number on that transformer to even begin to try and track one down.
