Results 1 to 7 of 7
Thread: Fanuc 0 MC, 001 TH Alarm, while DNC
    Mar 2007
    RI
    Dear all,
    Can anybody tell me how to solve alarm 001 (TH alarm) while my Fanuc 0 MC is drip feeding from PC? Manual says something related to unknown character on the tape, but i'm sure nothing's strange in the program..
    Thanks..
    Sep 2005
    Fanucs use the ISO 840 character set, and any non-ISO character can cause a TH alarm. ISO 840 is basically a "subset" of ASCII Even parity code. ASCII contains all the letters of the alphabet (upper and lower case), plus the numbers and the punctuation marks that you see on your computer keyboard. ISO, on the other hand, only has UPPER CASE letters, numbers, and a few selected punctuation marks. Most DNC systems are set up to send ASCII Even parity, so any non-ISO character in your program can cause the Fanuc to give the TH alarm. Characters like these:
    Any lower case letter.
    These punctuation marks: !@,$^&_{}|\;"<>? and '
    Notice that some punctuation marks are OK, like the forward slash (block delete), the asterisk (multiplication in a macro), and the decimal point are allowed. Others, like the double-quotation marks are not allowed, so any comment in the program like one of these will cause a TH alarm:
    N001 (TOOL 2 - 1/2" DRILL) - the double quote mark is illegal
    N001 (tool 2 = 1/2 inch drill) - the lower case letters are illegal
    N001 G90 G00 X1,2345 - the comma character is illegal
    If your program is all ISO 840 compatible, then you may have another communication problem, like a mis-match of the "stop-bits" setting. There is a parameter in all Fanuc controls for baudrate and "stop-bits". If the baudrate doesn't match the DNC system, then you won't have ANY communications at all. If the stop-bits setting doesn't match the DNC system, you might get occasional TH alarms even if the program is otherwise OK. If the stop-bits setting is mismatched, then you'll get TH alarms kind of randomly at different points in the program each time.
    Mar 2007
    RI
    Thank you Dan..
    I'll recheck everything according to your complete explaination. May be I missed something.
    Nov 2009
    india
    001 th parity alarm com in my dnc
    Oct 2010
    philippines
    can any body help me to resolve TH PARITY ALARM on SNK RB-2NM (fanuc controls)? we're having a hard time in DNC machining in remote condition because of this alarm.
    also we encounter COMMUNICATION ERROR during DNC machining also.
    PLEASE PLEASE. help us on this problem. thanks.
    Registered dcoupar's Avatar
    Mar 2003
    Quote Originally Posted by mhykel View Post
    Did you read Dan Fritz's earlier post?
    Oct 2010
    philippines
    Smile PARITY
    yes, I did sir. and I already applied his ideas. I change the parameters of pc and machine, right now we're on the process of trial and I'm glad that somehow it works. We're about to do an actual dnc machining by next week, we hope that it works continuously. thanks.
    1. Fanuc 6mb alarm help please.
      By mt92 in forum Fanuc
      Last Post: 02-22-2011, 08:50 PM
    2. 086 Alarm on Fanuc OM
      By darrylh in forum Fanuc
      Last Post: 07-13-2009, 09:59 AM
    3. FANUC 0M - alarm 520
      By promech in forum Fanuc
      Last Post: 02-19-2007, 11:41 AM
    4. fanuc 11t alarm need help please!
      By tomtech in forum Fanuc
      Last Post: 01-30-2007, 06:02 PM
    5. Fanuc 6M alarm: 231 -Z OT.
      By thanhct in forum Fanuc
      Last Post: 12-01-2006, 06:31 AM
