Did anybody having ladder diagram for Moriseiki SL6 with Fanuc Controller 6T.I want the details to set the timer values as the values intialized.Please reply me. Problem: Turret is not properly indexing and it is over shooting or not in reach to limitswitch to close the clamping confirmation signal.Problem observed after initailization of bubble memory due to alarm 901 & 904.Parameters reloaded and ok. only timers values not known. |
To display the pc params press the param push button until top of screen says PC PARAM. Counters are params 2001,2002,2101,2102. keep relays are 3001-3004. Timers are 1001-1019 in msecs. To change counters, turn program protect OFF. |
| you may try these pc parameters settings 1006 = 100 1009 = 1000 1010 = 100 1014 = 8000 1015 = 100 3002 = 10000001 or 10010001 3003 = 01000000 for 10 stations turret or 10000000 for 12 stations turret. Good Luck! |
| Thanks guys! I found the PC paramenters. But there are values in there but I do not know which ones to adjust for my turret. I need to set timer 3,4,and 5, for the turret functions according to the fanuc manual. Right now the turret timers are way too high and every function of the turret takes about 5 seconds before it excecutes. The book says for example timer 3 set to 200ms. How does this value get entered in the PC parameters? I also am not sure why the timers went high after the 904 alarm? you would think they would be zeroed out if anything. Thanks in advance for your help. |
PROBLEM SOLVED!!!! Thanks to your info I set the timers values and all is good. I answered my own question about which timer value from the manual coensides with what PC parameter. Timer 1 = 1001, 2 = 1002, etc. After the 904 alarm, all the timer values went to 6350. Does anyone now why? Are PC parameters backed up when I do a regular parameter back up?Thanks again for the help. |
Not if the control is a Series 6. Machines equipped with this control were generally supplied with a Hard Copy of the Ladder logic. You may be lucky and still have a copy in the maintenance or wiring manual of the machine. Regards, Bill |
| PMC Ladder Upload/Download - Fanuc Powermate D | RLMTS | Machine Problems, Solutions , Wireless DNC, serial port | 9 | 11-19-2011 10:00 AM |
| fanuc-o ladder | Bill Clark | Machine Problems, Solutions , Wireless DNC, serial port | 9 | 09-29-2011 01:35 PM |
| Fanuc Series 15-M Trouble uploading Ladder Program | grege101 | Fanuc | 5 | 12-13-2007 09:38 PM |
| Bostomatic 3200 PLC Ladder diagram | javed08 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 12-16-2006 01:40 AM |
| Fanuc ladder editing card | bob1371 | Fanuc | 1 | 04-10-2006 10:50 AM |
