0i MD position display
Results 1 to 3 of 3
Thread: 0i MD position display
    Feb 2018
    United Kingdom
    Default 0i MD position display
    Fanuc 0i MD on Hardinge GX600 VMC - no manual
    OK, still getting to know this controller.
    Run a code using my G56 workshift and G43 H1, run finishes, go to handwheel to move the axis and make some program tweaks, the display is not showing the G56/H1 position? Is this normal? do I really have to MDI>G56/H43 to make my tweaks? and what is it actually showing, doesn't seem to be the home position either? hope I'm missing something obvious here,
    Cheers
    Mar 2017
    Default Re: 0i MD position display
    What do you mean "make tweaks"?
    It is always easier when asking a question that involves code to post the referenced code, so that we can all be on the same page.
    Feb 2018
    United Kingdom
    Quote Originally Posted by generaldisarray View Post
    This isn't a code issue, it's about the position display - I've since found that when a run is complete - m30 -the control defaults back to g54 and cancels the tool offset. If I want to adjust any dimensions I need to see the tool position in context of the current prog offsets. Is this controlled in a parameter? Someone suggested whilst proving the code to bale before the m30 and go straight to handwheel without resetting?
    Sent from my SM-A300FU using Tapatalk
