- Need Help!- G41 issue
G41 issue
Fanuc 0i MD
Bridgeport/Hardinge GX600 VMC
Treat me gently, new to Fanuc mill.....
No conversational on this machine, machining a hex, tool heading off to unpredictable positions?
clockwise climb mill
10mm dia cutter
hex ct 0,0
D1=10
G56;
M6 T1;
G43 H1;
M3 S1500;
G0 X30 Y0;
Z-5;
G41 D1;
G1 X10.97 Y0 F100;
X5.48 Y-9.5;
X-5.48 Y-9.5;
X-10.97 Y0;
X-5.48 Y9.5;
X5.48 Y9.5;
X10.97 Y0;
G40;
G0 X30 Y0;
What am I missing? Is it 'cause the shortest length is close to the cutter dia?
Cheers, bspear
Re: G41 issue
Looks ok.
Can you show the obtained toolpath? At least a rough sketch.
Dia is not an issue in outward machining of a contour.
- You may not post replies
- You may not edit your posts
Forum Rules
