Hello,
I have a cnc tour colchester (electronic triumph)
When I start the CN fanuc, I have this message (1008 AXIS OVERLOAD DETECTED).
and when I try to move on the X or Z axis, it moves a very small movement of 1 mm only and I receive a new message (414 X-axis detect error), after I check the diagnostic messages number 200 I found OVC = 1 (OVERCURENT) and when I set the reset the error is gone and it returns the same problem of displacement with 1 mm
I check the motor and the cables I found that they worked well.
I hope to find who to help me
thank you very much sir for your answer, I check the hardware and I found them that it works very well but I found a loss of parameters LADDER PMC (timer counter Keep relay and data )knowing that I've found that all the parameters are initialized to zero so I propose that if any of you or if you know someone who has the same turn to help us by the sending of parametre for uses it to settle mine.
