Problem iTNC530 HEIDENHAIN
Results 1 to 13 of 13
Thread: iTNC530 HEIDENHAIN
    Jul 2016
    Egypt
    Default iTNC530 HEIDENHAIN
    hello . my machine iTNC530 HEIDENHAIN
    when i just press on power bottom all axis give me to much vibration and the display got this message
    8650 IZT value of power module is too high
    can any one help me please
    Mar 2016
    Poland
    Default Re: iTNC530 HEIDENHAIN
    Unfortunatelly it's major failure of control hadware.
    We had it in our iTNC and usually service would replace NC box, but our electronic guys replaced some microchips and it helped. Dunno what was it specificly.
    Jul 2016
    Egypt
    thank you for reply
    can you tell me what do u mean by (NC BOX)
    Dec 2011
    Hungary
    8650 I2T value of power module is too high <axis>
    Oscillation occurs. Mechanical problem. Too loose ball screew or bearing.
    Jul 2016
    Egypt
    thanks all. what i did
    1 i replace the all drivers from other machine x and y and z and power supply
    2 i check all bearing . it is OK .also i check all rollers x and y and z . it is OK
    3 i disconnect the x axis and try to run
    4 i disconnect the y axis and try to run
    5 i disconnect the z axis and try to run
    same problem . and all drivers is running good on other machine
    any one can help
    Dec 2011
    Hungary
    Which axis indicates the error? (8650 I2T value of power module is too high <axis>)
    Reduce the MP1510.x parameter to half! (.x=0:axis X, .x=1:axis Y, .x=2:axis Z)
  7. #7
    Jul 2016
    Egypt
    Quote Originally Posted by csg67 View Post
    the error display with all axis
    first with x and when i press any key its indicates with y and then with z
    its appear with all axis succession
    and please try to more explain with what i can do ?
    and really really thank you
  8. #8
    Jul 2016
    Egypt
    please help ??
  9. #9
    Jul 2016
    Egypt
    any one can help please
    machine is stile down
  10. #10
    Jul 2016
    Egypt
    no help up to now
    please reply ?
  11. #11
    Jul 2016
    Egypt
    no one have this error before
    please help
  12. #12
    *Registered User* Kinj1988's Avatar
    Aug 2018
    Default Re: iTNC530 HEIDENHAIN:
    Quote Originally Posted by JAMES_2000 View Post
    please help
    Take all axis on motor encoder if you have than take trial and confirm...
    - - - Updated - - -
    please take all axis on motor encoder and take trial...
  13. #13
    Aug 2018
    Post Re: iTNC530 HEIDENHAIN:
    HI, IN MY MACHINE SUDDENLY COMING DEVICE OVERLOADED NOT A SUCH PROPER ALARM AND THAN I CHECKED HELP ITS 24960 ALARM SHOWING CHECK FAN BUT ALL FANS WORKING FINE..
    CAN ANY ONE TELL ME WHATS A ISSUE?
iTNC530 HEIDENHAIN
iTNC530 HEIDENHAIN
