#3002 is a read/write variable.
Its value is preserved even after a power cycle.
It measure ON time of CYCLE START lamp in 1-hr increment.
Good day folks,
I've exhausted all my search options and found nothing that address my specific issue.
I have a 35i milling control. I am trying to use the #3002 hour timer to extract cutting times. From what I've read, I reset #3002 to zero before the start of my cutting path. At the end, set another non-volatile variable to the value of #3002. I'm expecting this value to be expressed in some expected format. I don't actually know what I'm getting.
At around the 15 minute mark after I've reset the #3002 variable to zero, the elapsed time (by setting another NV variable to #3002's value) is reading a value of .00099111111. I can't even imagine what this is telling me. I thought it was supposed to be expressed as hours in a decimal format...say 15 minutes would be .25. Obviously this isn't the case. I'm not a newby as far as macro programming, but this has me baffled.
Can anybody fill me in on what I'm seeing and what to do with it?
Many thanks!
- Newbie- Accessing Macro Variable from another macro
- Problem- Macro b variable order
- Need Help!- Macro Variable #500
- Macro/Variable Programing
- Problem- macro error 3002
Have you tried using something like this:
#500=[#3002*60]
It would give 60, 120, 180 etc.
sinha_nsit,
No disrespect intended but we do this all the time. Is something different with the 35i control?
I do not think it is control dependent. Same behaviour is expected.
The manual says "1-hr increment". Without checking, I just assumed that fractional time is not stored.
Thank you for useful information.
So, for 15 minutes, #500 stores 15?
I have a doubt.
When the time is in hour, and you multiply it by 60, it should be in minutes.
How to explain 0.25 for 15 minutes?
.25 hour = 15min.
Thank you all for your posts. I have decided to use a millisecond timer instead since it is giving me output that I expect.
Obviously you may all continue this discussion if you believe it is productive.
There are 60 minutes in 1 hour which means that if you run your machine for 60 minutes then #500 would equal 1 (for 1hr), but anything less than 60 minutes is now equivalent to 1/3600 (the 3600 is the # of seconds in 1 hr.). So if you run your machine for 6 minutes #3002 will equal .0002777778 x 6 (.0016666668). You then have to multiply that by 60 to get the portion of the hour the machine was running. In this case #500 would equal .1 (.0016666668 x 60), if you run your machine for 15 minutes then #3002 equals .0002777778 x 15 (.004166667). Multiply that by 60 and #500 would equal .25 (.004166667 x 60).
What you are saying is correct with regard to #3002.
But, #500 is not same as #3002.
You have defined #500 as #3000 x 60
Because #500 is #3002 multiplied by 60, what you are saying about the value stored in #500 is not correct.
Somehow I am not able to convey to you what I have in my mind.
Never mind. Let us stop this unproductive discussion.
