Fanuc Spindle Drive - Control voltage current requirement
Hi; I've been retrofitting a Fanuc 6MB based VMC with modern electronics. I used the Pico PPMC board set (Jon from Pico has been unbelievable with support) and LinuxCNC. It's going great.
My question is about feeding the existing Fanuc spindle controller (A06B-6044-H007) with the 0-10V control voltage. My Pico DAC "stalls out" at ~2.0V of supply. If I unhook the DAC from the spindle controller, it outputs 0-10V just fine but can't get above 2.0V when connected. If I feed the controller with an external linear power supply, everything works great. Speed goes up and down correctly with 0-10V.
My assumption is that the Spindle controller needs more than the ~20mA the DAC will supply.
I'll measure the actual current used in each case.
Re: Fanuc Spindle Drive - Control voltage current requirement
I measured the current when operating the spindle amp from an external power supply, the circuit takes 28mA, so that seems the issue. Has anyone else run into this?
Erik,
Have you considered using a Rail to Rail OpAmp hooked up as a voltage follower? Something like a Texas Instruments TLC2272CP (digikey part# 296-1812-5-ND) might work... as it doesn't need a +/- voltage input (aka you can run it on a 0 to 16 volt supply) and it will kick out 50 mA per channel. You could even parallel the two sides and double current output.
