I am working on reverse engineering a touch probe and integrating it into the machine. I need to know what does skip mean and how is it used( not skip command in code '/')
In Fanuc controls the skip command is usually a G31, it’s non-modal. When one or more axes are moving in G31 move the axes will stop immediately when a skip signal is input to the control from the probe or other device. Once the motion stops the program proceeds to the next line in the program.
