Try holding RESET and DELETE at power up then go back into Boot Mode and restore.
I've been fighting with a Fanuc Oi Model D controller. I was able to solve this problem 2 days ago but it's back again. During the boot process I get the error "reset request is not accepted" I was able to eliminate this error and get the controller and IPC to connect by restoring the SRAM. The problem was back today after the IPC had locked up yesterday so I once again set out to restore the SRAM but the following error appears during the restore process "Restore verify error". I'm using the same back up file from 2 days ago. I do suspect a possible bad optical communication card on the IPC but thought I would check in to see if anyone else has had this problem and what they did to solve it. Thanks guys!
Rob
- Need Help!- Fanuc Oi-MB "750" and "5136" error
- "Probe" and "Verify" not working - Mach3 & ESS
- Problem- How to remove error " Turret out of position" in Ge fanuc 21i-t controller for lathe?
- Does anyone remember seeing a "Fanuc" brand BTR model A16B-1200-027?
- FANUC 6M MODEL B CHANGE "[ ]" CHARACTER TO "( )"
Thanks for the reply. I'm getting the error during the rrestore process. I used the same file for the restore 3 days ago and it worked. Now when trying to restore the "restore verify error" pops up. This controller has the IPC interface with the backup sram file being loaded from the hard drive. ~Rob
You may have a bad memory card in the controller.
