Results 1 to 8 of 8
Thread: GE Fanuc 18i-MB: Memory Card Error 0030
    Nov 2006
    Question GE Fanuc 18i-MB: Memory Card Error 0030
    Hi Gents,
    Short story version: Inserted Card, completely shorted out panel, power up again, reload sram, reads memory card fine, powered out machine, power up the next day, Memory Card Error 0030. Op manual has no record of a memory card error 0030.
    Planning to box up unit and mail into GE Fanuc for evaluation and repair.
    Any other last ditch solutions/experiments welcome!!
    Fire Away!!!!
    Thanks!!!
    Andy in WI
    Mar 2007
    What kind of card are you using?? Do you have your I/O channel set to 4?? Did you change the ladder diagram??
    Registered dcoupar's Avatar
    Mar 2003
    Are you using a Compact Flash card?
    Nov 2006
    Yes: Compact Flash.
    Also ordered the ribbon cable that attaches to the card adapter yesterday. Hope it works!
    Mar 2007
    Messages
    Here is a list of memory card errors and cautions.
    Attached Thumbnails Attached Thumbnails GE Fanuc 18i-MB: Memory Card Error 0030-error.jpg   GE Fanuc 18i-MB: Memory Card Error 0030-error1.jpg
    Nov 2006
    Hey Thanks! I guess I have an older manual.
    My manual:
    B-63534EN/01
    I have tried formatting and erasing from the 18i unit too.
    Mar 2007
    Correct manual
    That is the same manual I have, but I was looking in the maintenance manual B-63525EN/02. I can just look through them all faster because I downloaded the CD with all the operator, parameter, maintenance as well as servo motor, servo amplifier, and spindle motor manuals. If you contact GE FANUC you could probably get the CD for about $60.00.
    Mar 2005
    I've been looking for 18i Model A, B and C manuals on PDF. Fortunately the net brought me the Model A books in PDF but I still would like the B and C model manuals
    I particularly would like the maintenance manual for the Model 18iMB / 18iTB with the list of modules. GFZ or B-63525EN or maybe its 63527EN
    I'm also looking for the manual GFTE-598-EN and GFTE-589-EN too.
    Greg
    1. Fanuc 16i memory card
      By jamie pinols in forum Fanuc
      Last Post: 02-25-2007, 07:50 PM
    2. Replies: 9
      Last Post: 01-11-2007, 10:27 AM
    3. Memory card
      By M-man in forum Fanuc
      Last Post: 07-17-2006, 04:00 PM
    4. EMC memory error
      By tomekbrzozowski in forum LinuxCNC (formerly EMC2)
      Last Post: 07-03-2006, 04:04 PM
    5. Fanuc 6M-b max memory card A87L-0001-?
      By Drew in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 03-25-2005, 08:08 PM
