Unfortunately the 6T is not quite as easy. This should help though.
1. Zero return X axis.
2. Change parameter 12 bit 0 (1 to 0/or 0 to 1).
3. Exchange the parameters between 143 and 147 but leave the signs. (143 is always positive, 147 is always negative value).
4. Change the sign on parameter 82, do not change the value.
5. Shut the machine off and swap motor wires on X axis servo (Switch XA1 and XA2)
6. Locate the Pulse coder on the end of the Ball screw, and switch wires on Pin A and B, also D and E in the connector housing, If you find the pulse coder in the Yellow cap, then skip next procedure(procedure 7).
7. Switch polarity on Tacho Generator on Pin A and B on the yellow cap.
8. Swap the Jog '+' and '-' by changing wires. (swap wires 576 and 577).
9. Restart the NC.
10. If you have FAPT and are using it, you must change the sign of MTF parameter 1050.
