- Manual guide i on a 30i control......
Hi everybody,
I'm testing a macro with the simulator in Manual guide i,
and been searching in the books without help.
Actually, it will skip all my variable in the program (#500= x.xxx etc..) and the skip block sign (/),
so nothing will work.
Is there a parameter for that ?
Did that a few years ago on a Oi control and it was ok.
Anybody have the same problem ??
Thanks a lot
Re: Manual guide i on a 30i control......
Updating my previous post...........
Here a test I made:
O0001;
#500=2.0
G0 X1.0 Y#500
M30
It went to X1.0 Y2.0, but the #500 variable still at 0 !!
So could the MGi transfert variable elsewhere ??
is your machine 1 one-path system ?
MGi will not interfere.
regards
Sorry, not sure what you mean by "one path system"
I can program in MGi and out of MGi too, but the simulator is only on MGi
Thank Norbert
- You may not post replies
- You may not edit your posts
Forum Rules
