Fanuc O-M Alarms #1006 and #409 on crt
Results 1 to 4 of 4
Thread: Fanuc O-M Alarms #1006 and #409 on crt
    Apr 2010
    Default Fanuc O-M Alarms #1006 and #409 on crt
    Need Help!!!
    When giving machine control any spindle command,
    We are getting alarms #1006 and #409 on crt and alarm 12 on Spindle Amplifier module # A06B-6088-H215#H500
    Member tristarcnc's Avatar
    May 2017
    Default Re: Fanuc O-M Alarms #1006 and #409 on crt
    This is a common alarm for spindle amps. If your motor and motor power cable meg fine the issue is with the spindle amp. Check out our website, www.tristarcnc.com for pricing.
    Apr 2010
    I do not have a meg meter to check with, so I disconnected the U , V , W , wires from the spindle amp and gave it only an S1500 command and still got the same alarms.
    Would this indicate issues are with the A06B-6088-H215#H500 Spindle Amplifier Module and not the cable or spindle motor?
    May 2017
    The problem is within the A06B-6088-H215#H500 spindle amp.
