Need Help! Fanuc 21i-T improper G-code G13.1
Results 1 to 5 of 5
Thread: Fanuc 21i-T improper G-code G13.1
    Nov 2017
    Germany
    Default Fanuc 21i-T improper G-code G13.1
    Hi guys,
    when i write my program with a inter-polar milling operation on my Colchester machine,
    i noticed that the g code 13.1 will cause an error named improper G-Code.
    why is this G-Code improper?????
    what can i do to solve this problem ?
    waiting for your thoughts
    greetings from Germany
    May 2016
    United Kingdom
    Default Re: Fanuc 21i-T improper G-code G13.1
    Max
    please post program so we can see problem
    Nov 2017
    Germany
    Quote Originally Posted by mbservice View Post
    Max
    G21
    G92 S4000
    G28 U0 W0
    G0 G94 X120 Z1 T909
    M109
    GO C0
    G12.1
    G97 S1200 M13
    G1 Z-1 F700
    G1 G42 C-30 X55
    G1 X40 F200
    G1 C-20
    G1 C20
    G1 X-40
    G1 C-20
    G1 X40
    G40 X60
    G1 Z2 F700
    G13.1
    M110
    G28 U0 W0
    M30
    Jan 2010
    Norway
    Strange if it allows G12.1 G13.1 should also work, what about G113?
    Dec 2012
    The Netherlands
    Hi Max,
    Post the line G97 S1200 M13 before the G12.1 ( or G112 ).
    Change GO C0 to G0 C0.
    Regards,
    Heavy_Metal.
