Ok so I have this rockford planer mill that was retrofitted with a 0MC control sometime in 1995. the control was removed from a Cincinnati 25 hc with a serial number of 178. the machine was moved recently and lost its parameters. I have been tasked with trying to get this machine operational again. yesterday the machine wouldn't do anything but I changed parameter 905 bit zero to 1 and the drives actually came up getting rid of the 401 (vrdy) alarm. At this point I'm not sure if the rest of the settings and parameters are correct. I am new to FANUC as far as this stuff goes but we are making progress. I'm going to attach the information I have gathered on the equipment thus far, and I am hoping someone out there can provide some insight to this issue. maybe someone has a set of parameters off a similar control. thank you in advance!
Peter Swartz
Cowlitz River Machine
503-754-3104
Fanuc 0Mc
Main board: A20B-2000-0170/07B SERIAL NO: 3200000877
DISPLAYED ON SCREEN AT STARTUP: 0469-05 PMC N112-01
MEM: A16B-2201-04A
I/O BOARD: A16B-1212-022
AXE BOARD: A16B-2200-0390/09B
POWER UNIT: A16B-1212-0100-01 MFG NO: P53P00922
SERVO AMPLIFIERS
X: A06B-6066-H006 A2 NO. ES20264
Y: LOOKS THE SAME BUT THERE IS NO TAG
Z: A06B-6066-H006 F3X 00897 A2
SERVOS
X
5MM/ MOTOR REV MODEL 30S A06B-0590-B074 #7008 DATE 94 01 TRQ (STALL) 37Nm AMP (STALL) 16A INSULATION CLASS F EXCIT PERM MAGNET VOLT 156V 3 PHASE 8 POLES 1200RPM AMB 40 DEG C PULSE CODER
Y
5MM/ MOTOR REV MODEL 20S A06B-502-B074 #7008 NO C94ZA1373 DATE 94.12 TRQ (STALL) 23Nm AMP (STALL) 20A EXCIT PERM MAGNET VOLT 146V 3 PHASE 8 POLES AMB 40DEG C PULSE CODER
Z
2.5MM/ MOTOR REV MODEL 5S/3000 TYPE A06B-0514-B574#7008 NO C94ZC3189 DATE 94.12 TRQ (STALL) 5.9Nm AMPS (STALL) 10.2A INSULATION CLASS F EXCIT PERM MAGNET VOLT 107V 3 PHASE 8 POLES 3000 RPM AMB 40 DEG C PULSE CODER
