401 SERVO ALARM : Y AXIS VRDY OFF
Results 1 to 3 of 3
Thread: 401 SERVO ALARM : Y AXIS VRDY OFF
    Oct 2010
    Default 401 SERVO ALARM : Y AXIS VRDY OFF
    I have alarm on my Omnitech sellex pal with fanuc control
    401 SERVO ALARM : A AXIS VRDY OFF
    Can somebody help me with that ?401 SERVO ALARM : Y AXIS VRDY OFF-img_5720-2-jpg
    May 2016
    United Kingdom
    Default Re: 401 SERVO ALARM : Y AXIS VRDY OFF
    Bit of a general alarm you need to check amplifiers
    Apr 2017
    yes, check amplifiers but also these diagnostics help:
    The details of servo alarm are displayed in the diagnosis display (No.
    200, 201, 204) as shown below.
    #7 #6 #5 #4 #3 #2 #1 #0
    200 OVL LV OVC HCA HVA DCA FBA OFA
    #7 (OVL) : An overload alarm is being generated.
    #6 (LV) : A low voltage alarm is being generated in servo amp.
    #5 (OVC) : A overcurrent alarm is being generated inside of
    digital servo.
    #4 (HCA) : An abnormal current alarm is being generated in
    servo amp.
    #3 (HVA) : An overvoltage alarm is being generated in servo
    amp.
    #2 (DCA) : A regenerative discharge circuit alarm is being
    #1 (FBA) : A disconnection alarm is being generated.
    #0 (OFA) : An overflow alarm is being generated inside of digital
    servo.
    201 ALD EXP
    When OVL equal 1 in diagnostic data No.200 :
    #7 (ALD) 0 : Motor overheating
    1 : Amplifier overheating
    When FBAL equal 1 in diagnostic data No.200 :
    ALD EXP Alarm details
    1 0 Built–in pulse coder disconnection (hardware)
    1 1 Separately installed pulse coder disconnection
    (hardware)
    0 0 Pulse coder is not connected due to software.
    Rensito's Avatar
    Feb 2022
    It's a general warning that amplifiers should be checked.
    fall guys
