The 750 alarm is most likely a result of the 5136 (FSSB: NUMBER OF AMPS SMALL). One or more of your servo amps is not communicating properly. This could be a faulty fiber optic cable from amp to amp or a problem with the servo amp. You said you replaced one, was that from the control to the first amp.
