The 15A controls had no PCMCIA card; the 15B series did, but no user files such as the LADDER can be stored on it.
Hi!
I really need for your helps about Ladder Fanuc!
I want to download Ladder of Fanuc 15M to PC by Fanuc Ladder III, but I have some problem :
- I connected and set up the communication of FAPT III
. Setting Port = Com 3
. Baudrate = 4800 ( The same PMC I/O)
. Parity = Even
. Stop bit = 2
- Set Keep relay K17.1 = 1 (01000110)
- Select PCPRM - I/O - Channel I/O = 0 (cannot change)
- Select Output - P-G (FAPT Ladder) - Execute
- In the FAPT,
. Tool - load from PMC - I/O by monit online - Connect and wait a few seconds the FAPT alarm disconnect.
. When I select I/O by "I/O" key operation - ladder - Finish ( I see the monitor of CNC machine notices output complete but The FAPT software still executing and nothing happens. When i cancel, the FAPT notices " MCARD file not found ".
Fanuc Ladder III doesn't support the 15MA controller. You need A08B-9201-J501#EN (PMC-N)
Can you guide me or give me the software to load ladder?
It was an old DOS program. I haven't used it in years, I don't know if Fanuc even still sells it. You may try searching the net. sorry
You cannot use Faptladder 3 for this. Are you still in need of help?
