Hey everyone,
I keep getting this OT001 Z +OVERTRAVEL (soft 1) alarm when I try to auto zero return.
Back story, this machine has worked fine for the past five years. It has recently sat for a few months with no use. One morning I went to turn it on to use it and it's been doing this ever since.
So far I've tried to turn the controller off, press P and CAN at the same time to get it to clear but it has not worked.
Also, the three limit switches are not even touching the dogs.
Any help on helping me get this Z axis to zero?
The soft over travel is set by parameters. The P CAN doesn't work on that machine. The . - setting is good till zero has been established. I can't answer why is happens now, but I can answer how to fix it. This alarm is triggered when you Z axis "Machine" position enters an area out side a parameter setting. Parameter 5220 is the plus direction and 5221 is the minus. This means how far plus and how far minus can you go from machine zero. Try putting a larger number in 5220.
Any fanuc experts out there?
I'm no Fanuc expert, but.. In your original post you mention that the machine has been unused for some months... have you checked the limit switches operation? You could have a switch that is stuck closed (or open I suppose) so the machine thinks it is at the Z limit. If you have the electrical diagram you could trace the limit switch back to the particular input module. Although now that I think about my 11m... the input module doesn't have indicator lights on it.. You may need to look at the ladder or diagnostic screen.
cj
