Need Help! Fanuc series 10 programming
Results 1 to 8 of 8
Thread: Fanuc series 10 programming
    May 2013
    Default Fanuc series 10 programming
    Hello, I am new to the world of cnc and I just got a nakamura superturn 2 with a Fanuc 10TE-F controller. I do not have the programming manual and I would like to know how to use my lathe. Would it be possible to have the programming manual or help to build one.
    May 2013
    Default Re: Fanuc series 10 programming
    I need help or at least a good start.
    Member positiverake's Avatar
    Sep 2005
    Do you know how to set it up, touching off tooling etc. ? does this control have FAPT?
    Feb 2006
    india
    Basic programming codes are same on all Fanuc machines. Set-up method would be a little different. For learning programming, grab any programming book to start with.
    May 2013
    Quote Originally Posted by positiverake View Post
    Well i do know how too setup a cnc lathe, bot not on tha contrôle, and yes it does have FAPT ..... I was planning to use G cood
    Sep 2005
    Well then sinha_nsit reply is a good starting point, imo Fapt is great for lathes, it will generate the g code for you.
  7. #7
    May 2013
    I do master the G code, i have rite many program over the Time
    But i was using a milltronic cnc lathe that have the original manuel
    For the machine. Yes milltronic use standard fanuc g code.
    The ting giving me problem is the contrôle , did not find the user manuel.
    And i did not figures how to puntch the program in .
    Is it posibul on this control to run a program wit the MPG. Like fadal contro do ?
  8. #8
    May 2013
    Quote Originally Posted by 4MInnovations View Post
    By the way , it is m'y associé that started this post, he is effectiveley new in cnc Word, but i do have cnc noledeg but not in anglich riting soree if its hard to read tanks for yor compreandtion .
