Just seeing if anyone can help would be much appreciated?
Trying to program this old Wasino machine and keeps throwing up a feedrate alarm.
011 P/S alarm.
Seems like I've tried everything to clear it but I must say I'm not much of a Fanuc person.
Live day to day on an Okuma.
Shifted federates around etc.
Any clues would be great
thanks
Will
Alarm 11 means feedrate not commanded or inadequate feedrate.
If you have actually commanded feedrate with an F-word, try increasing its value.
Probably, your program is in feed/min mode and you are assuming feed/rev mode. Try F10.0 (Use decimal point. Depending on a parameter, 10 might be interpreted as 0.01 in mm mode)
