Need Help! Fanuc 16i Parameter 1851 question
Results 1 to 3 of 3
Thread: Fanuc 16i Parameter 1851 question
    May 2015
    Default Fanuc 16i Parameter 1851 question
    IF machine has negative backlash from my ball bar reading but value in 1851 is a 1. According to this i would need to change value to -100 to make a 10 micron adjustment. However Fanuc manual states value must be greater the 1. has anyone ever encountered anything like this?
    Machine is a Kitamura HX400i@.
    Apr 2011
    Default Re: Fanuc 16i Parameter 1851 question
    you can set negative values in 1851
    Dec 2009
    ROMANIA
    i set value with negative sign only in Y axis on a turning lathe bacuse the Y is referenced in middle of ballscrew so you travel for work both sides.
    the rest i never put negaive,it seems is not working on one way travel ballscrews.
