When I machining threads in my HAAS VF2 machines always the threads are not neat. They don't have sharp edges. Thread gauges are not enter to them. Material is stainless steel. I am not using any tapping attachment. Only tap attached to the collet.Similar Threads:Need Help!- THREADING: How to add threading parameters to the Init file? threading issue/questionProblem- sherline/deskcnc threading issueNeed Help!- Threading Issue with SL80Problem- Roll threading 2-56 look issue
Check bore diameter.
For M12 x 1.75 we use 10.3mm drill. I know correct dia is 10.25 but 0.05mm for easy tapping.
Higher bore dia would not give sharp edges. 10.25 may not be available, so 10.2 can be used.
View Tag Cloud
Forum Rules
