In Fanuc PWE is not enabling and System hard key not working.
The problem is parameter write is not getting enabled. Unit is not going in System mode.
At present APC alarms are displaying in message.
For this we were trying to set reference. We found parameter write is not enabling in SETTING (HANDY). There is no response if we press SYSTEM hard key.
Model of CNC : FANUC Series 0i-TD.
Machine Builder Name : Colchester Harrison 600 Group
Please suggest us how to fix this problem. Waiting for your replies
Re: In Fanuc PWE is not enabling and System hard key not working.
I checked with parameter 3299.0 then parameter write is getting enabled. But the system hard key is still not working.
Thinking some hardware problem I changed the keys PCB board and checked still same problem.
Is there any parameter/password to enable the system hard key. If system hard key work then only I can access the parameter 1815 etc.
