Need Help!- FANUC PMC EDIT ISSUE
i used FANUC with PMC 31i-B.
I edit custom PMC with Fanuc Ladder III but have a issue
this ladder when running on machine:
When x5.7 ON
or both K74.0 and R2011.0 ON
but output is R2200.0 is not ON.
please help me to edit it ! Similar Threads:
Re: FANUC PMC EDIT ISSUE
Either the coil R2200.0 is used twice some where or there is a jump instruction prior to the coil somewhere above.
If jump JMP instruction is high all the coils inside the jump will not turn ON.
Sent from my SM-G950F using Tapatalk
Search in ladder that this coil should not have 2 coils in the ladder.
I search by address map . this address not use.
Gửi từ SM-G610F của tôi bằng cách sử dụng Tapatalk
Is it a robodrill...
Yes. My machine is fanuc robodrill
Check in custom PMC manual some address can not be used as a coil these are only for DI and DO for main PMC to Custom PMC..
Forum Rules
