Fanuc 32i, MDI won't clear after cycle finished
On 18i, MDI program is automatically cleared once finished. How do I make it so that on 32i the behavior is similar?
Thank you. Similar Threads:
Re: Fanuc 32i, MDI won't clear after cycle finished
3204#6 = 0 would clear MDI program after execution.
Nice On 18i I'm used to typing several lines of code in MDI and then cycle start would run all those lines entered. However, on 32i it will only execute the last block, unless I move the cursor to the beginning. Would you know if this is achievable as well?
Not sure, but try this:
Set 3204#6 = 1 and 3203#7 = 0, and insert M30 as the last line of the MDI program.
Also ensure that 3404#4 = 0.
Thank you, although I didn't chance the MDI behavior because the operators are used to using it this way.
Forum Rules
