Hi, I need someone to help me.
I have a ROMI 10 winch of the year 2005 with Fanuc control. I need to change the timing of the lubrication pump and the electrical manual does not specify which timer number it is. The manual only says that value takes each timer but not so that it is each one.
It would be in the ladder. If this machine has the gear type oil pump, and seems to be using more oil than it used to, it's a mechanical problem. The manifolds are stuck open, allowing oil flow while the pump is running.
