use q setter to ensure drill is broken
Results 1 to 13 of 13
Thread: use q setter to ensure drill is broken
    Jan 2016
    Default use q setter to ensure drill is broken
    hi, is there a way how to check drill lengt in automatic mode using q setter? i tried this
    T101
    M80 ( Q SETTER DOWN )
    G91 G28 Z0
    G94 G31 Z-100.0 F20
    but movement dont stop if i touches q setter by hand during motion z-100, is there any parameter to change, to make q setter act like probe, only in z axis on lathe? it looks like it can somehow works, i can do programmaticaly everything, but i cant get decision or if touched continue, if not stop.
    i know about renishaw solution. little expensive, we dont have yet many orders to buy this. machine is doosan puma 240 or lynx.
    Dec 2009
    ROMANIA
    Default Re: use q setter to ensure drill is broken
    i think the setter is made to stop only in jog mode not mdi mode,you need to edit the ladder to enable the G31 to be active also in mdi mode.to make this to work.
    what model of Fanuc you have?
    PS:if that will not work i can say that there is another trick you can use,you can use a macro program that can monitor the spindle load,if spindle load is high than usual when tool is new, that means the tool is broken but this is second plan i can help.
    try first plan and we will see.
    Jan 2016
    fanuc 21i.
    does tool load monitor works with small center drills also? is it that sensitive
    Feb 2006
    india
    Are you using G-code system B on your lathe?
    May 2016
    United Kingdom
    what Q setter do you have
    Jan 2016
    sintha: probably, not sure but code with macro B works
    mbservice: dont know manufacturer, i will try to find it, im not in work now. its odd but if only image could help u, otherwise yesterday. image from web, q setter is same.
    Attached Thumbnails Attached Thumbnails use q setter to ensure drill is broken-optional-q-setter-l150-series-turning-centers
  7. #7
    Feb 2006
    india
    The q setter might be defective. The motion must stop when the tool setter is hit.
  8. #8
    Jan 2016
    no,probe is fine. i will try to use g37 automatic tool offset in z, instead of g31.
    i found this,it gave me some ideas, if g37 works, maybe together with compensation table bellow i will be able to do that. at least it worh a try.
    O9020(PRE-SET OD)
    IF[#20EQ#0]GOTO51
    GOTO50
    N0001
    #1=#4014 ; Read and save work coordinate, G54,G55 etc.
    #2=#5221 ; Read and save G54 X....
    #3=#5222 ; Read and save G54 Z....
    G28U0
    G28W0
    #5221=#0 ; Set G54 X to Zero
    #5222=#0 ; Set G54 Z to Zero
    G54
    G0T#20 ;
    M80 ; Swing pre setter arm down.
    G0Z372 ; Move into z-pos to read X-axis
    X187 ; Move X-axis into Pos.
    G36X181 ; Launch X- axis messuring, X181 EQ expected contact pos.
    G0U10 ; Retract 10mm
    Z400 ; Move into z-pos for reading Z-axis
    X140 : Move z axis in pos for reading Z-axis.
    G37Z393 ; Launch z-axis messuring, Z393 EQ expected contct pos.
    G0W10 : retract 10mm
    G28U0
    G28W0
    M81 ; swing pre setter arm up
    #5221=#2 ; Restoring G54 X to same value it had before calling macro
    #5222=#3 ; Restoring G54 Z to same value it had before calling macro
    G#1 ; Set work coordinate to same as befor macro call. G54,G55 etc.
    M30
    N50#3006=1(MESSURE OD) Skip this line if you don’t want to press cycle start twice.
    GOTO1
    N51
    #3000=1(NO TOOL SELECTED) ; Launch alarm if no tool are selected.
    M30
    Attached Thumbnails Attached Thumbnails use q setter to ensure drill is broken-untitled-png
  9. #9
    Feb 2006
    india
    This means that q setters are not designed to work with G31.
    Incidentally, #0 is not always equivalent to 0.
  10. #10
    Feb 2006
    india
    If you have taken the program from the MTB manual, it is fine; otherwise, the measurement position may not be the same.
  11. #11
    Jan 2016
    setter is marposs, i didnt find any code examples on their website. owner finally consider q setter check as slow and risky, so i'm quit until i have time to testing. still believe it can work and have what i need, thx bb
  12. #12
    Feb 2006
    india
    Your program seems ok.
    Even if you do not intend to use it, you may like to check if G36/37 works with it.
    Just give a G36/37 motion in a safe zone, and activate the setter with your hand. Does the tool motion immediately stop?
    If yes then this method can be used in future.
    Before conducting this experiment, note down the offset values which would get affected. Would need to restore these afterwards.
  13. #13
    Dec 2009
    ROMANIA
    Quote Originally Posted by bemik5 View Post
    use what i told you,spindle load monitor macro program to check for broken inserts during cutting.
