Need Help! 04 alarm on Fanuc A06B-6134-A301
Results 1 to 6 of 6
Thread: 04 alarm on Fanuc A06B-6134-A301
    Sep 2017
    Default 04 alarm on Fanuc A06B-6134-A301
    I got this alarm 2 week ago. We send this unit to Fanuc Beijin, they checked it and say no problem.
    Please help
    Member guhl's Avatar
    Aug 2007
    Russian Federation
    Default Re: 04 alarm on Fanuc A06B-6134-A301
    is it on the display of the drive unit?
    what does show CNC screen?
    Sep 2017
    India
    Hi Alex
    Check your 3 phase supply. Check it from mains to MCC Contactor and isolation transformer to the drive.
    Also tell me when you are getting this alarm. Is it immediately after Power ON or is it after the emergency release.
    Also what is the message on the CNC Screen.
    Apr 2011
    (1) Meaning
    In the main circuit, the DC voltage (DC link) has dropped.
    (2) Cause and troubleshooting
    (a) A small power dip has occurred.
    → Check the power supply.
    (b) Low input power supply voltage
    → Check the power supply specification.
    (c) The main circuit power supply may have been switched off
    with an emergency stop state released.
    → Check the sequence.
    Sep 2017
    drdos, thank you. Solved. Contactor (Shihlin S-P35T) on the machine DC entry was broken. After we changed it - all is ok.
    Registered ariangcomau's Avatar
    Sep 2017
    regina terrace
    Hi dear . I need ergently wiring diagram fanuc w1(wirecutting) year 1988 .to repair servo alarm v 440 and 441 .
    THANKS.
