Fanuc 21-T Servo Motor Replacement / Re-establish zero return position.
I'm about to swap out the X axis servo motor on a Nakamura Tome SC-300. Any suggestions on an easy way to re-establish the X-axis zero return position. Is there anything I should do or verify before I remove the motor? (It is still operational, it just does not run at rapid traverse). Thanks for any help you may have to offer.
