You need to change bit of parameter 0070.7
When I transmit a program from my Fanuc 0Tc lathe control to my computer, it arrives with different formatting. Specifically, all of the character spaces are removed and there are two blank lines between each line of code. Is there a way of controlling this? There is no change in formatting when I transmit from the computer to the control. I use Easy DNC.
