I have a DMTG Lathe with a Fanuc Control iO Mate -TD.
The problem that I have is that the spindle doesn't rotates when you send the order pushing the cycle button. But if I push and hold the cycle button the spindle does run. This happens in the MDI mode and also when running a program. I am very sure that it is a parameter or ladder program issue.
Does anybody has any idea of how to solve this problem?
What parameter should I check?
