Need Help! Read exernal signal with macro ( ladder (X002.1). >> IF [2.1]=1 THEN #nnnn=0 )
Results 1 to 14 of 14
Thread: Read exernal signal with macro ( ladder (X002.1). >> IF [2.1]=1 THEN #nnnn=0 )
    Sep 2017
    Turkey
    Default Read exernal signal with macro ( ladder (X002.1). >> IF [2.1]=1 THEN #nnnn=0 )
    Hello, I would really like to try and write into one of my macros to look at a particular diagnostic input (2.4) or ladder (X002.1). Part of the macro might be { IF [2.1]=1 THEN #nnnn=0}.
    I want to cheking with macro . Please share sample.
    How can i read external signal. ?
    Can have a Macro at the Ladder or Diagnostic inputs?
    Any insight would be great, thanks!
    Apr 2011
    Default Re: Read exernal signal with macro ( ladder (X002.1). >> IF [2.1]=1 THEN #nnnn=0 )
    Fanuc does this VIA the PMC ladder. You would take X2.1 and write to a G-coil. So you would write normally open X2.1 turning on G54.0 coils. Then the macro would look at the status of G54.0 by stating IF #1000 EQ 1 GOTO 100 where 100 would be a NET number in the macro program. Assuming you have a 16/18/21 CNC type.
    Sep 2017
    Turkey
    Quote Originally Posted by drdos View Post
    thank you for answer
    firstly, i am not expert
    Our Mahine hyundai Fanuc 0itd;
    how can i connect X2.1 to G54.0 coil? do you have example or video link?
    Sep 2017
    Turkey
    I found a video.
    is video same your way?
    staarting 12:00.
    please check it.
    Apr 2011
    Yes
    Feb 2006
    india
    May look at the attachment for some information.
    Attached Thumbnails Attached Thumbnails Read exernal signal with macro (  ladder (X002.1). >>  IF [2.1]=1 THEN #nnnn=0 )-interface-signals-pdf
  7. #7
    Sep 2017
    Turkey
    Thank you for sharing; it s great
    Quote Originally Posted by sinha_nsit View Post
  8. #8
    Sep 2017
    Turkey
    Ehat is your document name ? or links?
  9. #9
    Feb 2006
    india
    This was from this book,
    https://www.amazon.com/Programming-u...dp/0071713328/
    Its current price is about $38 (free shipping). It usually sells for around $55, the list price being $71. Grab if before amazon increases its price again. Kindle version is a bit expensive.
    Smid has not discussed advanced macro features such as this. His book is apt for only basic knowledge of macro programming.
  10. #10
    Jul 2005
    Turkiye
    Thanks Mr Sinha NSIT,
    Thanks Mr.Tayfur for video
  11. #11
    Sep 2017
    Turkey
    thank you for your feedback MASTER Sinha
    How can i create a line in ladder on FANUC machine (with on machine keyboard, not use PC program)
    do you you have video or pics.
  12. #12
    Sep 2017
    Turkey
    Merhnbalar Selim
    Fanuc tezgahı kullanarak ledder diyagramına nasıl ek yapılır? bunun la ilgili örnek falan varmı? video olursa tabii süper
  13. #13
    Feb 2006
    india
    It is better to seek a professional help for ladder editing and related work. Any inadvertent mistake may prove to be too costly.
  14. #14
    Sep 2017
    Turkey
    thank you.
