After working perfectly for 3 years, suddenly the FANUC10 will not "Handshake" anymore , i have tried everything, new computer, new USB adapter, double check cable/wires/connectors.
problem description:
i use CIMCO NC edit , i press transmit in "NC edit" on the FANUC i am in tape mode i press start , code transmission starts , machine starts moving , TX in "NC edit" goes low , and here is the problem TX don't go hi again , FANUC runs out of code , and i get some errors "buffer overflow" or "SR590 ERROR".
if i go very slow "override 10%" i looks like it is working.
Anybody have any idea what could be causing this problem, FANUC memory problem maybe?
