The Fanuc PSU on the far left, if you want to isolate the Fanuc part from the machine, disconnect the 3 INCOMING AC cables at the bottom of the PSU, L1, L2, L3, should be red, white, blue . This will be hot so tape off end and secure. Then power everything back on and see if it trips the breaker.
