Add these lines in your program and run/test it on a safe Z-height.
Metric tap M10x1.5,
G95 ( MM/REV )
M29 S500
G84 Z-15. R3. F1.5
X-- Y--
X-- Y--
G80
G94 ( MM/MIN )
Regards,
Heavy_Metal.
Hello. Was hoping some could help me figure out how rigid tap on a Fanuc 15m on a Femco boring mill. According to the Fanuc 15m user manual, it say G84.2 is for right hand rigid tapping, but when I tried it, the machine gives me a invalid G-code alarm. Any help trouble shooting this would be appreciated.
- Need Help!- 1975 hitachi seiki bd-h horizontal boring mill w/30B fanuc control
- Rigid Tapping on floor boring machine.
- Boring, Face mill, End Mill and Circular Interpolation on Floor Boring Machine.
- Need Help!- FANUC 0T FEMCO DURGA 25E
- Need Help!- Drill cycle on a Fanuc 11m control in a Kuraki boring mill
Metric tap M10x1.5,
G95 ( MM/REV )
M29 S500
G84 Z-15. R3. F1.5
X-- Y--
X-- Y--
G80
G94 ( MM/MIN )
Regards,
Heavy_Metal.
PM sent
Thank for the replies. I'll try these suggestion when I get around to powering the machine back on.
:rainfro:
The Fanuc 15m programing manual dose not mention the use of M29 for rigid tapping. I know M29 is use on the Fanuc '0' & '18' series control. It is my hunch that the rigid tapping option is not turned active on this machine.
Dose any know the proper code for rigid tapping on a Fanuc 15m control and the alarm generated if rigid tapping is not installed on the machine. I perfectly fine if this option is not turned on. I just want to be able to use the rigid tapping if it is enable on the machine.
Do you have the Fanuc 15-MB with the B62564E Operator's Manual.
If so, pages 207 - 215 are about Rigid Tapping G84.2 and without the M29.....!
Check also your personal message.
Regards,
Heavy_Metal.
I am really sorry to hijack this thread but I am really desperate.
I have a femco wbmc 100r2 fanuc 15M and I lost the parameters and we have no backup. If any of you have a similar machine with the same control and brand name then it might work even if is not the same model. If some one has the same machine then I can and I am willing to pay.
Please email me to jolula@yahoo.com, that is JOLULA@yahoo.com
www.doctornumerico.com
cnc physicians
