Does anyone know where I can get some technical data for the KL-2200 spindle?
I use CNC Cookbook's GWizard feeds & speeds calculator. To calculate the F&S more accurately, it needs more specs than I can find. (I was able to find most of this data for the HSD spindle.)
The power curves for the KL-2200 spindle. I need to get the RPM vs HP graph.
I'm having trouble interpreting the little bit of data that I have found. On the Automation Technologies web page, they say: Speed: 8000-24000 R/min ( run speed at 60% or less than 80% of rated Max spindle)
What does that last sentence mean? Is the max speed 24,000, 14,400, or 19,200 rpm:?
Is 8000-24000 R/min the derated speed?
That the max speed should be 60% of 8000-24000, or 4,800 - 14,400?
That the max speed should be less than 80% of the rated Max spindle speed, where 24000 is the Max spindle speed, or 19,200 RPM.
What is the spindle acceleration, from 0 to max rpm, in seconds?
