PC to Fanuc 21T
Results 1 to 5 of 5
Thread: PC to Fanuc 21T
    Feb 2016
    Default PC to Fanuc 21T
    I've been doing some searching on this forum, but can't seem to find an answer....
    What is the best way to connect a PC to a Fanuc 21T controller??
    My lathe has a 25 pin male connector on the back. I'm thinking use a USB to 25 pin female cable? Is there a special cable for this, or a typical "printer" style cable?
    Thanks!
    Todd Rudaitis
    Orange, CA
    Apr 2011
    Default Re: PC to Fanuc 21T
    I have seen people have issues using the USB to serial adapters. Some seem to work better than others. I recommend that you stick with a PC that uses a real serial port. Here are the pin-outs that you requested. DOT NOT YOU A PRINTER CABLE AS YOU WILL TAKE OUT THE SERIAL PORT.
    Attached Thumbnails Attached Thumbnails PC to Fanuc 21T-fanuc-rs232-cable-pdf
    Dec 2009
    ROMANIA
    i use from long time the serial to usb cable with adaptor
    you need an adaptor from 25 pins to 9 pins that you have to open and rearrange the wires like the document.
    PC to Fanuc 21T-p_20170713_080845-jpg
    PC to Fanuc 21T-p_20170713_080853-jpg
    PC to Fanuc 21T-rs232-fanuc-png
    Feb 2016
    Quote Originally Posted by drdos View Post
    Does anyone sell a cable with this configuration??
    Todd
    Dec 2009
    ROMANIA
    Quote Originally Posted by tar356 View Post
    Todd
    i think not,you can spend 1 hour making it
PC to Fanuc 21T
PC to Fanuc 21T
