Hello everyone,
Looked through all posts with DPRNT info but nothing has worked for us.
Any ideas on what might help will be much appreciated
Hardinge VMC 600 II with Fanuc 0M-D and Yukiwa AC4-10 indexer control.
The following code works for us (ex. 90 deg incremental index
RRR is character string, G50 is incremental, A90000 is index
angle- controller needs to see 90000):
Not sure if this will help you directly, but it may give you some ideas.
The following G-code snippet is what I use w/ my Haas MiniMill w/ a Tsudakoma / TPCjr indexer setup:
G103 P1
DPRNT[/MOVA180.]
M21
G04 P1.
G103 P0
G103 P1 <- set look ahead to one line only
DPRNT[/MOVA###] <- cmd to be sent to indexer
M21 <- causes the command to be sent
G04 P1. <- dwell for one second
G103 P0 <- set look ahead back to default
I wrote a standalone program (DprntCvt.exe) so my G-code files can have the regular "N101 A180." blocks so the G-code files work as expected with my PC based verification tools. When I'm ready to take the G-code file to the machine I pass the G-code file through DprntCvt.exe which then translates all of the A-axis blocks to the DPRNT format.
We use Haas Indexers on our Machines. We made our own G code (g15) to control indexer through program. We will call G15 A90.0 for a 90 degree rotation. Below is the macro program.
